Hi all
I have a Toyota Aygo with what I believe is CVT transmission (I can put it in automatic but also switch to a manual + and - mode). For the last 6/7 months or so, it's started to become very jerky/kangaroo like when you're first moving off, much like you'd get in a manual if you were doing something funky with the clutch. This jerky/kangaroo movement is apparent in first and reverse (it will jerk and lurch forward a few times before eventually moving smoothly). Additionally, when it's behaving like this, the transition from first to second gear can be quite heavy/jerky too.
The issue only seems to happen if the car has had a chance to cool down; once it's been going for a while, there aren't any issues with this moving off smoothly.
The car has done 55,000 miles and as far as I know, has never had any work done on the auto clutch.
Do I need to start worrying about this? I do know automatics can be very expensive to repair when clutches start to go. I'm coming up to exactly 2 years of ownership and all my tax/insurance are due so if I should get rid of it, it's a good time to do so.
Many thanks for any thought.
#29.
#29.
