- 27 Oct 2006
- London
Is it worth upgrading from 6.1 ?
Any faster / does it use less ram ?
Cheers
Cheers
Try this, worked for me![]()
Depends on your needs. If you're happy with Jellyfish, then why go through the hassle? On the other hand, CM7 is slicker and quite nice on a Blade. I had it on mine before I gave it to the missus and bought a Galaxy S2![]()
Is this the ROM you need if you want to connect a PS3 pad to the GS2? I will be trying it out this weekend.
Yes, remember to put a bln kernel on it (menu and back buttons flash when you miss a call/text) and overclock to 1600 for awesome N64 performance.
Top one. Not sure about the o/cing to 1600 though![]()
Restore your nand backup.
Why?
The question really is... how do I enable the stock google homescreen.
Won't it run hotter, use more battery and possibly be unstable?
