CM battery life is fantastic comapred with villainrom I found....went from 1 day battery with villain to 2 with CM
I had the same problem, for your google things, you need to install the Gapps.zip files which installs all the Google apps (gmail, market etc).
To fix the camera, move the photos/videos you took whilst using the samsung rom to another location, or delete them.
Nope, the only problem i had was with no market/google apps. I couldnt see it anywhere on the CM7 website but with a little searching I found the reason, installed the Gapps via clockwork recovery (vol+/power/home button) and select to install .zip from sd card and it works perfectly so far.
1 - Yes for prolonged periods of high intensity use, but it never gets too hot.
2 - The opposite actually during normal use. For mobile CPU's with low power states, the quicker you can do the "work" and get back to the minimum power state, the better.
3 - It will either work or not generally.
I also undervolt my phone for ridiculous battery life gains!
The CM7 install instructions tell you to get it through the ROM manager which is automatically installed. Takes 2 mins and no messing around with digging around the net to find the right files, rebooting into recovery and all that crap.
Legend! Done it and its worked. Got access to marketplace again and all my contacts are back. Thanks again!![]()
