Hi guys,
I’m desperate for some tips.
Background:
Got a system:
Mobo gigabyte z390 ud
i9-9900k
2080ti
2 x 16GB Corsair vengeance rbg
M.2
850w aorus gold psu. And everything was working fine.
Decided to get a better mobo for over clocking with WiFi and Bluetooth. Got a used aorus z390 master from eBay. Rebuilt everything but when trying to boot it cycles through multiple error codes a couple of time and then stops at c1 and reboots, doing it all over again.
I’ve reseated ram sticks multiple times together and on their own, testing each stick, even tried a ram stick from another pc. I also disconnected every usb device leaving only the power plug.
Furthermore, I’ve reseated the gpu in another slot.
And finally I have also reseated the cpu, although I have to note that there were 3 pins which were slightly bent. Using a needle I tried to straighten them and looked ok to the naked eye.
Is there anything else anyone can suggest I could try before sending the mobo back?
Background:
Got a system:
i9-9900k
2080ti
M.2
