Cylinder Reservoir - HELP NEEDED! CONFUSED!
18 Oct 2012
Wales
Hi all,
I'v been mentally setting up my system and I'v got one question I cannot seem to get around.
I want a cylinder reservoir - I want the outlet tube heading back to the reservoir to insert directly in the top of the reservoir.
My dilemma is... that with the top port in use by the returning tube, how can I fill the system with liquid???
Here's an example of what I mean..
http://tinypic.com/view.php?pic=28s1zb9&s=7
I can't find any cylinder reservoirs with 2 ports at the top either - but I'v seem systems that have done it.
I was thinking of flipping a normal cylinder res, so there are 2 or more fill ports at the top - but most of them have a long inside tube, which would then be at the wrong end!
Any thoughts?
Thanks.
Nick.
This was how I used to do it - with the ek res upside down
Now I use a koolance D5 top and res - I use the 'base' as my top
As others have said very unusual rad setup.
Thanks for your replys..
The picture was just referencing how I want the reservoir to connect, I will be putting a 360 rad in the top of the case.
@shadowscotland - Did you have any problems using the res upside down?
@Ash2097 - Do you have a link fit one of those?
Cheers.
Nick.
Exactly what I need!
Where is that res from?
Was there an inner tube inside the res?
Finally, was there a trickling sound as the water enters the res?
Cheers.
Hi, my is roughly the same set up, l use a small measuring jug with a fine spout, l just unscrew the top lift up and keep the tube in the water till there's a gap and fill, about 2/3rds full.
