d/l windows 8.1 trial USB guide
24 Dec 2010
Anglesey
Can't find any guide over the internet on how to do this.
I want to download the 3 month windows 8.1 onto a USB, so when my new system is complete I can download it onto that.
Would anyone be able to take me through this by a step by step guide that's almost idiot proof?
It will be my first time doing this.
Any help would be greatly appreciated.
You should use a standard version of Win 8.1 if you're going to purchase it at a later date.
1) Grab the x64 ISO from https://drive.google.com/folderview?id=0B3c2hcaO4GgWbXB4Q0g5YkhHUVE&usp=sharing
2) Use http://www.microsoftstore.com/store/msusa/html/pbPage.Help_Win7_usbdvd_dwnTool to create a bootable flash drive
3) Follow this guide from step 3: http://gearnuke.com/clean-install-windows-8-18/
When it prompts for a key, use 334NH-RXG76-64THK-C7CKG-D3VPT - this product key is for the core version, I doubt you'll need pro. http://www.microsoft.com/en-us/wind...technologies/windows-8-1/compare/default.aspx
i tried a usb install, and ran into issues.
as far as i can work out, windows 7 usb boot tool didnt make the usb device read only, so installation kept trying to dump onto the stick first and gave a failed to install error (couldn't see / make partition on my ssd or hdd)
in the end i had to borrow a dvd drive.
I had to use a formatted 8GB USB Flash drive (4GB was not big enough) for my Win8.1 x64 ISO on USB,btw did mine in FAT32 with no issues.
+1
he/she said everything
