- 21 Apr 2006
I’m using a DIR-655 but I never seem to get the schedules to work correctly they fail to work at the times set, I have seen a few threads on the web with reports of funny problem with the schedules on the DIR-655 the questions are is there a fix for this or indeed a better 3rd party firmware available I’m currently using firmware version 1.11EU
The hardware version is A3. I did find a firmware version dir655_firmware_130.bin, but not sure if it’s a beta or whatever, the latest D-Link firmware is DIR655A4_FW121EUb05.bin which enables the Share Port USB Utility, which I'm not bothered with that at the moment.
D-Link technical just tell me to reset the router and put all the settings back in so to humour them I did that still the same.
Any help would be appreciated.
