TRUE HD MEDIA STREAMING HERE AT LAST!
D-Link are pushing the limits of wireless technology. Providing upto 600Mbps the D-Link DIR-855 Wireless-N 600Mbps Cable Router and D-Link DWA-160 Wireless-N 600Mbps USB Adapter allow true HD Video content to be streamed wirelessly.
Quadband technology supports Wireless-N signals in both the 2.4 and 5 GHz frequency ranges simultaneously at full speed. This true concurrent operation allows you to check e-mail and browse the Internet using the 2.4 GHz band while simultaneously streaming High-Definition (HD) movies and other media on the 5GHz band.
The 5 GHz radio frequency is wider and less crowded than the 2.4GHz radio frequency used by most wireless devices (including consumer devices such as cordless phones, baby monitors, bluetooth adapters etc) today. With up to 23 non-overlapping channels available on the 5GHz radio band, compared to only 3 on the 2.4 GHz band, users are sure to experience the full speed and Quality of Service needed to run even the most delay sensitive applications, such as streaming multiple HD videos across the network.
The DIR-855 features an OLED display that provides interesting readings regarding your network, such as throughput speed, WPS status and general usage. This monitor turns itself off after a while to avoid wasting power. If your router placement does not allow for easy access, a Yahoo!® Widget is available to get the same real-time network information delivered right to your desktop.
- Quadband technology, up to 600 Mbps aggregated bandwidth
- True concurrent 2.4GHz and 5GHz Wireless N operation
- One 10/100/1000 Mbps Gigabit WAN port
- Four 10/100/1000 Mbps Gigabit LAN ports with Jumbo Frame support
- OLED Network Activity Display
- QoS StreamEngine
- Built in NAT firewall
- MAC address filtering
- Web based GUI
BUY NOW.
- QoS StreamEngine
- Web based GUI
BUY NOW.
