D-Link DSL-G604T.  Has been working flawlessly for a year.
On it's one year anniversary - exactly to the day - the router seems to of totally failed. It now refuses to allocate DHCP IP Addresses. Refuses to go online. And worst of all - totally refuses any access to the config pages.
I was hoping to update firmware - but no access to the device.
What makes this _really_ bizzarre is I did manage to bring this box back to life for a short time. This was when I swapped it to a different mains socket and different phone socket. During this time I managed to login to the control panel, reset all the values (which had dropped back to default - this was before I had hit the reset button). Once everything was configured. Saved back to Flash and copied the data to the hard disk. Powered off and back on - still working.
So returned it to the room we usually have it in... only to find it has keeled over again!! No response.
Anyone else seen a D-Link router just "give up" like this? Any thoughts? Or should I just start look into the RMA procedure... (who wants to bet that there is only a single year warrenty on this... LOL)
Thanks in advance
- I have tested this with three different PCs.
- I have tested with different Ethernet cables.
- I have tried using static IP Addresses.
- The router doesn't return a ping, so the config pages can't be reached.
- The WiFi network is not not coming on and not visible.
- Lights on status panel show all is working fine - WLAN, ADSL, LAN.
- When I connect a PC, the PC acknowledges the cable is plugged in, the LAN light comes on on the router, and the PC starts trying to get an address. And then gives up...
- Have completed "factory resets" (again with correct light response).
Thanks in advance
