Hi my mum and sister wanted to share the cable connection which they have between their two PCs so I bought the following piece of kit from D-Link:
I installed the drivers for the router on my sisters PC connected via ethernet and then installed the drivers for the USB antenna on my mums PC and connected the antenna. However it does not connect. The rooms are about 8 to 10 metres apart and there are about 3 walls inbetween.
Is there something which I have done wrong? Do I need to install the router or anything else on my mums PC?
Many thanks for any help which you can give to me.....
- DI-524 wireless G router
- DWL-G122 wireless G USB adaptor
