D ram frequency wrong setting in bios ?
Setting the Memory Multiplier to x3.0 would give you 780mhz, so just under its 800mhz rated speed (CPU-Z will say 390mhz). Be sure to set the memory overvoltage to +0.3v for its rated 2.1v.
Thought id ask 1 more question cause i was reading about ram ratio and how it should match with your fbs and got me thinking if i me setting are wrong still lol
my cpu running at 260fbs x10 multiplier
So that means my ram would have to be running 520mhz if using 1:1 ram ratio and from what i read ment to be faster ??
I sort of lost myself with this lol
Just want to make sure i got everything set up right :)
cheers for any help guys :D
No real reason to run the memory at 1:1. If you bought 80mhz memory then you may as well get the most out of it.
What you can do is drop the multiplier to x9 or x8 and raise the FSB to match your current clock speed (eg - 325x8). Even dropping to 372x7 and running 1:1 would be a good idea. Tho 400x7 should be easy enough to get too.
