Aside from the obvious answer that DVI should technically give a better quality picture on a decent display, is there any compelling reason why I should spend the extra money on a new display with DVI input rather than just D-sub?
I have an existing 17" LCD which has both inputs, and I'm looking to get a second display as I need extra 'screen real estate' as they say (I have to compile a lot of information for my work and I'm intending to have my report on one screen, with browsers, Acrobat etc on the other).
Now, I'm looking at getting maybe a 19" widescreen to keep the height of the two displays fairly constant; my graphics card has one DVI-out and one D-sub, so one of the displays will be relegated to D-sub, and my initial thoughts are that because I'll also be gaming to some extent, the widescreen will be my primary display. This would suggest, to me, that the widescreen should ideally be connected via DVI; however, going back to the opening question, getting one with DVI input means more money.
As I'm not a hardcore gamer, do I need to have the new display on DVI? Is there any functional difference between the two (in terms of how they handle switching screen res for games etc)?
Thoughts please?
Al
P.s. before anyone suggests bigger displays etc, desk space is at a slight premium so I've pretty much decided on that aspect already!
Thoughts please?
Al
I'm hoping that because I'll only be using the old display as a secondary one and not for any games etc the downgrade in quality won't overly matter...
