D-tek Fuzion with Socket 1366
10 Jun 2006
W. Yorks
I am assuming there is no way I can use my exisiting D-tek Fuzion waterblock with an i7 (socket 1366) :confused:
I should think D-tek will release a mount but the problem is the i7 IHS is a little larger than the skt775.
excellent have been waiting for this :)) if anyone sees one in stock elsewhere please send me a PM
The ASUS P6T (not deluxe) has a second set of holes on the motherboard so you can use any S775 cooler or block.
You would have thought they would have done this with the deluxe hence the DELUXE part of the title.
On a side note does anyone know if its best to remove the nozzle kit for the fuzion when using an i7
