- 22 Jul 2014
- Oxon
I can get the 100D w/ 24mm EF-S 2.8 STM and 55-250mm STM lenses for £531.55 or the D3300 w/ 35mm DX 1.8 and Tamron 70-300 VC lenses for £648.
On the Canon side, the 24mm is wider and possibly of less use than the 35 on the Nikon. The zoom has less reach and is a cheaper offering, but it's quite good optically according to reviews. The 100D has much less battery life than the D3300 and a much older sensor.
In terms of bodies, they're both pretty light and compact. I've used a 100D before, and whilst not the comfiest to hold, it was good enough.
My feeling is that the Nikon setup is probably worth the extra in the long run, for the better lenses. If Canon weren't offering £70 cashback on those three items at the moment vs £20 from Nikon, the decision would be simpler.
Thoughts?
Thoughts?
