Hi all,
I am re-designing my loop and would like to add another D5 pump in the loop. I have decided to go with a single loop as from what I have been reading, single loop will be fine for what I am doing.
I have CPU block and 2 x GTX680 blocks. 3 x EK CoolStream RAD XTX 360 radiators so I feel that two pumps would be best and also offer redundancy if the other pump somehow fails.
I have been looking for a D5 Dual top. I am a fan of EK products and have seen the top I want, but it has been discontinued. The newer EK Dual top is for a dual loop system and I am not sure if it can be made to work with one loop and have the pumps in serial. Also, I am not sure if the newer one allows be to attach a res directly onto the top like the previous version does.
Your thoughts please.
Thanks
Thanks
