D5 pump question
28 May 2010
London, UK
Got a VPP655 - single(D5 with out the top) today but when I turn the impeller by two fingers, it makes a squealing noise :eek:
That can not be normal right?
I don't have the top till tomorrow to test it under water properly.
This didn't happen with my MCP355 so I find it bit worrying!
No, not at all. It makes a whining sort of noise, which muffles right down when you fill the loop with fluid... on mine at least!
So I got the top for the D5 today and did a test with just a small RES connected with a 12" tube.
No sound apart from air bubbles circulating and that went away after 1-2 minutes!
D5 even at highest setting IS much quieter than my DDC 18W!
But it is big!
