Hi All,
I am considering an upgrade to my existing D5 pump which is the very original VPP655 Vario with 3pin speed output and power via 4 way molex.
I heard that the newer ones weren't an actual improvement but there is such a selection now that I kind of lost track what is what.
Any recommendation for what would be an actual upgrade and what to avoid?
I run big a** 1/2" ID pipes
I was thinking the Alphacool Apex for the added PWM control.
Thanks!
Thanks!
before it used to be coil whine on the GPU that was the standing out sound from the silent PC, but now its the pump.
