So I have 2 D5's in series with what I call a highly restrictive loop. Using intel burn test the cpu max temp after 20 runs seems to only increase by a degree when I lowered it from setting 5 to setting 1. Is this normal?
Pretty P.O'd considering I spent quite a bit on two d5 vario's and a dual pump top to to replace my old D5 b
