D5 - Too little?
27 Feb 2012
Before i commit and hook up my pump etc....i'm starting to question whether 1 is enough even on the 5th setting.
4x 360 rads, 1 GPU and 1 CPU block, a lot of angles, with a fair height.
I have another D5, but is being used on my spare computer. I'm the type of person to do and ask questions later, but i'd rather not start only to find i need to bleed the lot only to add a second later down the line.
So, Watercooling section - what do you think?
I personally think yes, i've had a decently restrictive loop before and the D5 smashed it albeit not with the extra height etc.
No, it's not too little. You might have to turn it up a bit more than previously (unless it was already on 5). I've got 1x 360mm and 1x 280mm + 2 waterblocks + 400ml bay res + separate top and setting 1.5 - 2 on the D5 vario pushes the water around well enough for me. 4+ seems like a Tsunami. Maybe you need more with lots of 90° fittings, or if you want a fail-safe in case a pump dies.
I had similar when I did my first Titans loop, so it would cope.
3 x Gpu
2 x mobo blocks
1 x Cpu block
1 x 360mm 1 x 240mm rads
Lots of angled fittings
With a spaghetti junction of tubes which ran with the pump on setting 3.
However, a 2nd as redundancy wouldn't hurt IMHO :)
Well, I think another D5 would be needed to boost flow with that many rads.
1 D5 is good for about 4m worth. 360 rads stretched out are 720mm from the design.
With rads alone you've 2880mm (2.8m), add in the other parts of the loop, I think you'd run into some issues.
