D50 & Dust
9 Mar 2003
Manchester
Hi all,
Any reccomendations on where to send or preferably take my D50 to get the sensor cleaned (I am in Manchester). Tried blowing with rocket, sucking with green-air thing and even wipoing with the green-air sensor swabs result......
adding more dust bunnies.
So want it clean ASAP and cheap as poss.
Ideas
Ta Chucks
I would send it to Nikon service. I understand they only charge about £25, which is less than the cost of the "Green - air thing". They will also check the calibration of the various components of the body as well.
Do you send it to the main Nikon service centre or one of the others ? As for the calibration etc, I would be surprised if it need it as it is a couple of months old and has done but 1000 shots.
Thanks
I would be inclined to give them a ring...
These are the authorised repair centres that specialise in your product type.
Nikon UK Ltd
380 Richmond Road
Kingston upon Thames
Surrey
KT2 5PR
Tel 0870 770 0232
Fax 020 8541 4590
http://www.nikon.co.uk
