D500 Help
1 Dec 2003
Liverpool
Hey
I sold my XDA Exec and now have a D500 anyway i have all my contacts stored in seperate files as 'MSG Files' and i need a way to mass transfer them all via my bluetooth from my bluetooth laptop to my phone
How can one do this? Support is greatly appreciated
Thank you.
Chris.
ah! i'm not usre if u can do anything with that file type from xda to normal phone!
what you should have done is sync it with outlook (i'm quite sure you can do it with Samsungs, i know for sure you can with most if not all Nokia's and Sony Ericssons) as this is the most versatile way to get contacts from one phone to another! (well at least you know next time!!)
only thing i can suggest is to try finding some1 else with a XDA and load your contacts on there, and then sync with outlook! though bit long winded as you'll have to:
1) backup their contacts first
2) erase theirs off the phone
3) put yours on their phone
4) sync with outlook so your contacts are on there,
5) erase your contacts off the phone
6) restore their contacts back!
so a bit long, but the only thing that i know should work. although if there is a way to interperate msg files, maybe you have a chance!!
Good luck!
