D500 or K750i?
2 Oct 2003
Porthcawl (S.Wales)
Can't make my mind up which one I like most, after something smaller than my current fone (6630i)
Which one would you get and why?
what do you need from your mobile?
i had the d500 before and its a great little phone does everything good, not a bad camera for a 1.3megapixel one altho theres no zoom on the best quality mode. the k750i has a better camera but when i used one i didnt like joystick at all. i would choose d500 just because of the troublesome joystick.
I prefer the E700 to the D500 in every way.
SE have better cameras all round.
Any reason for those 2 phones and no others?
had a K500 for ages so used to joystick, if the joystick wasn't an issue would you still choose the K750i?
Just basically looking for something similar to my 6630 in terms of features but in a smaller size, I've had a play with a couple of D500's but never had me hands on a K750i yet, they both look pretty good for the money.
D500 is £100 on PAYG and K750i is £130
Budget is around £130ish and they seem about best for that ammount o cash
edit: E720 is £90 atm, looks pretty similar spec to the D500 too
if the k750 didnt have a joystick then yeah i would have gone with that. k750 is a good phone but ive heard so much about the joystick buggering up after 3 months which would really annoy me but if you dont mind gettin it fixed in 3months choose that because its a good phone.
hmm, that would be annoying lol
so question of a D500 or a E720 now lol
definitely d500 over the e720,used the e720 the d500 is better than it in every aspect.better camera quality,sound and screen.
