D600 - 1gb Transflash Card - Problem ?
Sam
Sam
12 Jan 2003
Surrey
Hi There
Just wondering is there any problems with a 1gb transflash card and the D600, the guy @ the 02 shop told me that theres problems with the phone crashing when using a 1gb card. Just wanted to check before i order a card as i would prefer a 1gb to a 512
Cheers all
Sam
Sometimes phones are designed to work with the available memory sizes available at the time, these usually need an update (when available) to work with newer/bigger memory cards.
Does anyone use a 1gb card with there D600 on here ?
If so are you experiencing any problems ?
Sam
I'd like to know this also. My fiancée, fiancée's aunt and my sister all have the D600 (2x o2, 1x Orange) and are all after 1GB cards.
I've not had anyone come in and say there's been a problem. But I've not tried it personally.
Guy next to me at work is using a Sandisk 1GB TransFlash, and its working fine as far as I know...
Thats what ive ordered, 1gb scandisc transflash card £25.00 :)
Sam
