Hi,
Been thinking of changing my D7000 to a later model and probably sticking to DX so ..D7200(probably will go out of stock soon) and D7500(not worried about single card slot) are the two i've been eyeing up.
So both have better AF,more Megapixels than the d7000 ,both will be better in low light , oh and both have newer sensors.
My main photography is Landscape , Grand kids and flowers and the bees and butterflies that land on them,no BIF, only the ones that are perched .
My lens are the Sigma 18-35 1.8, Nikon 70-300 vr fx and Nikon 40mm macro.
I am leaning towards the D7200 because i shoot in A mode and use "easy ISO",which i like, never got into auto ISO, I think i read somewhere the D7500 can't be set up for easy ISO, though with the higher ISO in the D7500 compared to the D7000 ,auto iso would work better...less noise, maybe no need for "easy iso"?
I have bought grey market before and will do so with new camera...some will like..some won't.
So any past D7000 users who have moved on to either the D7200 or D7500...or maybe both, what were the improvements you found over the D7000?
Thanks
Thanks
