Hi there, im praying you lot can shed some light on this little predicament.
Basically my dads computer has been running fine for a fair while then all of a sudden it wont boot. The internals have not been touched whatsoever.
On boot up (when it finally boots up!) sometimes it says that the spu is unworkable and when you go into the bios, random characters start appearing on the screen and blocks of different colours, then it turns itself off.
I have no idea whats going on and as i dont have another computer with similar components to hand, cant check everything.
Thanks again.
Rob
PS. Its a P4 3.2 Northy with Abit IC7-G max motherboard. Ive tried reseting the CMOS.
Thanks again.
Rob
