- 29 Sep 2003
- Newcastle upon Tyne
Hi there,
I'm using the Vista compatible version of Daemon Tools (the latest available). However, whilst I can get it to install fine, the virtual drive isn't assigned a driver letter. When I try to manually set one, it reports that it is unable to do so. As a result, none of my images will work. How do you set the drive letter?
Regards,
Micahel.
Regards,
Micahel.
