I'm getting a PITA SPTD 1.60 issue from Daemon Tools, along with 'kernel debugger must be deactivated'. Taken form the DT forums:
source
I'm not sure about doing the bolded bit. Am I enabling permission under regedit, or under explorer? Am I deleting the entire sptd directory in regedit, or do I llok at it a different way? Any help appreciated.
OS upgrade screws SPTD configuration.
Delete Daemon Tools installation folder, disable SPTD in registry, i.e. open regedit, go to
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servic es\sptd
and change Start to 4, then reboot.
After reboot enable all permissions of sptd/cfg key, then delete entire sptd key, and reboot again.
Now re-install.
source
