why can't I install this?
I used to have it installed, I then un-installed it, now when I try to install it, it says internal device error, contact support.
I have installed c&C3 since is there cd checking software blocking it, but if I remember it doesn't un-install it when you un-install c&c3.
any Ideas?
Also is there any alternatives?
any Ideas?
Maybe try somesort of .reg cleaner Deamon may of left some corrupt files for the virtual drive?
