Daft Question - Cleaning Using a Brush
14 Aug 2008
North Sea
Hi guys,
As the thread title suggests, I'm considering using a brush to attempt to clean some of the inaccesible nooks and crannies in my case and on my motherboard. Particularly the fans on the northbridge/southbridge, and and few other places around some of the hard drive cages and some of the drive bays. If I were to use say, a horse's hair brush, should there be any issues with static potentially killing some of my components?
Thanks, Mike.
I use a small brush to loosen the stubborn stuff and then a can of air to clean.
Once the loose stuff settles then a length of 7/16 pipe left over from my water cooling taped onto the vacuum cleaner gets pretty much everywhere :)
