daft question
8 Apr 2008
i have a tuniq tower, running on a e6750 mildly oc'ed to 3.2
i find this odd but i am easily able to twist the cooler even with the screws tightened. will this ruin the bond between the thermal material and cpu and require a proper re-seat, or will it make no difference. the paste was the aftermarket tuniq paste - tm 2 ??? from memory
has anyone experienced similar with the tuniq? or have any theories?
if it helps my temps at the mo are 36c - which pretty quickly rises to 60 ish when gaming.
thanks
I don't think you should be able to twist it?
How far did you screw in the thumbscrews?
