Daisy chain or mesh routers
18 Mar 2007
Hello
OK basically I have a busy little three router setup.
However I'd like my internal traffic to stay in a local ring instead of going through the main router connected to the Internet.
Is it better to mesh the two routers together who both also have a direct cable to the router connected to the net or do I just daisy chain them together?
They are in bridge mode anyway so I'm not sure it makes any difference?
I did find giving both the routers a direct line to the Internet router increased performance but that means internal traffic is also routed across it and I don't want that. So will mesh work or daisychain them? I'm concerned meshing will just result in it sending it any old way anyway!
Yes I guess im trying to control the flow of data to keep it in the internal network and not cross the internet router, which pushes me in the daisy chain direction.
The only alternative I can think of would be to have some sort of Firewall/NAT between your internal routers and the internet. Something like a m0n0wall box or something. Although down that route lies expense :)
Yeah my routers are in bridge mode anyway so i suspect that it will make little difference whatever I do.
I just want to try and stop network traffic from crossing the main router connected to the internet but if I mesh it it will use any old route whereas if i daisy chain it forces the internal traffic between the two routers. The downside of this being a perfromance drop, however they are all 1GB wired connections so I doubt it will be that much of drop if any...
Routing is not the correct word. Routing is only when packets cross the boundary of a subnet, so as long as everything is on the same subnet (you said the two "internal" routers are configured in bridge mode, so yes), then the traffic flowing from "internal" router 1 to "internal" router 2 via the "external" router, is just using the "external" router as a switch. If you *really* wanted to avoid this, then you would have all three routers plugged into a central switch.
