Hi'a, before i take the plunge and splash a load of cash on fans and cables i'd just like your opinion on this to see if you think it'll work/ or not.
I have a zalman mfc2 which accepts x3 3pins and a 4pwn pin fan. The fan controllers power by a single molex.
I intend to get use two fans on the cpu via the pwn connection with a y splitter so i can control both at the same speed.
with a further five fans connected to the fan controller, one connected by itself with a cabel and x2 of 2 i.e four fans connected to two fan connectors with y splitters. Would this work? I just wonder if the single molex would supply sufficent power to do this?
thank you for your help.
if this helps the fans will be 120mm AKASA AK-FN059 HDB Viper Fan,
alternativly with the psu fan i considered using a Akasa AK-CB002 PWM Fan Splitter Cable to connect the two psu fans with a ysplitter on the third connection to connect two case fans to it ?
