I've always been told this was an absolute no-no and thus have adhered all my life to the rule that this should never be done.
However with the outlets in my current flat it's really bloody awkward to have extension leads all over the place, and life would be considerably easier if I could daisy chain a few together.
So, putting my logical head on, I cannot see the problem?
So long as the total load across two power strips does not exceed the total power limit of the first strip, it shouldn't cause an issue? Perhaps the resistance of the extra connections may cause some reduction in power limit but I imagine this is minimal on our voltage-high amperage-low power we have in the UK?
So before I go blow myself up, I am looking to install strip B, into strip A. Strip A will have one Phillips Hue bulb only and be plugged into the wall. Strip B will have my PC (750w PSU with only one GPU, I'd estimate ~400W max.), my monitor and some KEF Egg speakers. These will be plugged into strip A through a WiFi plug.
Total plugs are 4, wattage is low, but it is split over two power strips.
Am I stupid?
Am I stupid?
