dam dvi
3 Jul 2007
Rochdale/whitworth
im goin 2 get a Sapphire ATI Radeon X1950 Pro 512MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail but its got 2 dvi and my moiter is analog i no il get an a adapter with it but iv try 1 on my x700 and it didn work so had 2 put it back in the analog sockit any 1 no a way 2 make it work if i get the x1950
well i was goin 2 get it all of overclockers coz iv got a xp3000+ a gig of 266mhz
ddr ram and a x700 i have around 350pounds 2 upgrade it and so for im thinkin of getin
GeIL 2GB (2x1GB) PC6400C5 800MHz
OcUK Huntkey 500W PSU
Intel Core 2 Duo E2160 "LGA775 Conroe" 1.80GHz (800FSB) - Retail
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard
*** do u think
and iv tryed lookin 4 an anlog x1950 but its hard 2 find
yeh it is coz if a cant get my moniter 2 work by a dvi 2 anlog adepter it means a new moniter
yeh i no but i tryed 1 on my x700 2 hav duo moniters but it didnt work it mite just be my **** moniter
More likely you had a faulty adaptor, or that particular card had a problem with its dvi socket.
DVI comes in two flavours, DVI, and DVI-D. The -D version is digital only, while the more common DVI includes the standard analog connections as part of its normal pinout. You just need the plug adaptor to make it work.
Even a ancient 'VGA' 640x480 monitor will work using an adaptor, just as long as you remember to set up the refreshrates, and resolutions properly. And by 'default' they should be set to the lowest level anyway.
Like mentioned, likely the adapter was faulty. But, GFX driver/Windows might not have picked up the switch to the other connector. Even if its 1 card, the connectors make it appear under Windows as 2 cards in order to support 2 monitors, etc.
