I have a palit super jet stream 980ti that's now faulty after I removed custom heat sinks.
I used Akasa thermal tape and was really careful but had to be quite forceful to pull a couple off and I think a memory module might be borked.
It boots into windows but won't install drivers and then there are black and white lines across the screen.
I upgraded to a 1080ti a few months back so Rather than bin it, do you think someone might buy a faulty 980ti at a knock down price? Especially in this crazy mining time. Can gpus be fixed?
Would only sell on the MM by the way, don't use eBay or owt else.
