damn bsod
17 Jul 2009
at home, you?
the windows driver framework has detected that a violation has occurred
0x0000010d
anyone have any ideas? my pc has crashed twice in the past half hour with this:confused:
Found this on a support site:
0x0000010D error is hardware error. Please, check your pc carefully or better show your system to specialist. In this case, I recommend you to do this because you need to choose good, new power supply unit
Id suggest, going back to stock settings (no OC) and trying each stick of ram individually. If you have a spare PSU test that too.
already back at stock settings, have been since my cooler died, was just sat listenin to music
ram is less than 12 months old but i will run a mem test, and psu is fine just used my psu tester and no problems
