Damn IE....
For the gap on the right hand side my guess would be that the padding or margin is causing the problem. You could try setting the default margins in the CSS with the following code; -
Code:
*,html,body{margin:0;padding:0;}
You'd then have to set all the padding and margin attributes yourself. It usually gives you better control of the style because you are making the decisions.
As for the <hr /> tag, IE just doesn't like it to be styled. Try applying a border-bottom to the p class="news" and the span class="date" selectors.
Can I ask what the problem is? I visited the site with IE and firefox and I cant see a problem (except the menu, the rollover has extra padding or margin so it moves the text out of position).
this works a little better:
h1 a:hover
background-color: black;
color: white;
border: 5px solid Black;
text-decoration: none;
a {
color: black;
border: 5px solid #acacac;
font-size: 11px;
background-color:transparent;
It will still look dodgy with that gradient background strip which I haven't used, and it messes up your links further down, but you can solve that.
Hmm try this (changes are bold):
h1 a{
color: Black;
font: Trebuchet MS, sans-serif;
padding:0 5px;
h1 a:visited
color: Black;
h1 a:hover
color: white;
border-top: 5px solid #000000;
border-bottom: 5px solid #000000;
a {
color: black;
font-size: 11px;
(I removed the 5pixel border that appears when you rollover the menu)
EDIT: ah I see why you used a border, altered above accordingly. Also change the h1 style to this:
h1 {
font-size: 11px;
text-align: center;
color: #564b47;
background-image: url(menbg.jpg);
border-top: 1px solid black;
border-bottom: 1px solid black;
padding:4px 0 5px;
That should fix it in IE and firefox.
