**DAMN ITS WINDY AT OcUK TODAY!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Not only have we had huge expansion on Gigabytes WindForce graphics cards, we also have several on special offer, check out these great cards at great prices now:-
Gigabyte GeForce GTX 560Ti "448 Edition" WindForce 3X OC 1280MB GDDR5 PCI-Express Graphics Card @ £167.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 560 "448 Edition" rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2, Battlefield 3, Skyrim with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 560 "448 Edition" packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 560 "448 edition" - arm yourself for battle.
Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. GIGABYTE Ultra Durable VGA can lower GPU temperature by 5% to 10%.
Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. GIGABYTE Ultra Durable VGA graphic accelerators improve overclocking capability by 10% to 30%.
Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency. GIGABYTE Ultra Durable VGA can lower power switching loss by 10% to 30%.
WINDFORCE™ 3X 3D-inclined fin design is GIGABYTE’s first generation triple-fan solution. It features 3 ultra quiet PWM fans, three copper heat pipes and a unique vapor chamber to strengthen the speed of heat dissipation.
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections
Features:-
- Core Clock: 732MHz (GF110)
- Gigabyte innovative low noise cooling solution
- Memory: 1280MB GDDR5
- Memory Clock: 3800MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 448
- Shader Clock: 1464MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 1x DVI-I, 1x DVI-D & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Warranty: 3 years
Was [£179.99] Inc. VAT
Only £167.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 560 OC 1024MB GDDR5 PCI-Express Graphics Card @ £139.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 560 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 560 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 560Ti - arm yourself for battle.
Features:-
- Core Clock: 830MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 336
- Shader Clock: 1660MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was [£149.99] Inc. VAT
Only £139.99 inc VAT.
ORDER NOW
Gigabyte GeForce GT 430 OC "Dual Fan" 1024MB GDDR3 Low Profile PCI-Express Graphics Card @ £49.99 inc VAT
The GT430 provides users with ultra-smooth multimedia entertainment. This makes it the ideal product for a home theatre PC. Accompanied by a low profile design and Blu-ray 3D acceleration the GT430 has the perfect compatibility and fit required for HTPCs and multimedia centres. The GT430 plays Blu-ray 3D playback with true HD and put's minimal stress on the CPU allowing crisp, clear viewing in excellent detail.
Specification:-
- Core Clock: 730MHz
- Memory: 1024MB GDDR3
- Memory Clock: 1800MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 96
- Shader Clock: 1460MHz
- Display Connectors: 1x Dual-Link DVI-I, 1x Analogue & 1x HDMI
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Dimensions: The card size is 6.3 inches x 2.8 inches
- Warranty: 2 Years
Only £49.99 inc VAT.
ORDER NOW
Gigabyte ATI Radeon HD 7970 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card @ £377.99 inc VAT
GIGABYTE introduces the latest exclusive "Triangle Cool" Technology to reach a better cooling performance. The latest patent pending technology combines fin with clip module in a special triangle shape. With the original anti-turbulence structure plus the new triangle cooling design, it enhances the efficiency of heat dissipation dramatically by minimizing the flow of turbulence between fans. Therefore, the "Triangle Cool" Technology provides a more efficient air flow for the cooling system.
Features:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Fastest single GPU graphics card on the planet
- Hugely overclockable
- Vastly cooler running than previous generation
- Quieter running than previous generation
- Compute Power: 3.5 TFLOPS
- Core Clock Speed: 1000MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 5500MHz
- Load / Idle Board Power: <300W / <3W
- Power Connectors: 8-pin + 6-pin
- Dimensions: H=38 mm, L=285 mm, W=126 mm
- Display Outputs: 1xDVI + 2x mDP + 1x HDMI
- 3yr Warranty
- AMD 3 for FREE Promotion including Dirt 3 Showdown, Nexuiz, Deus Ex Games (Subject to availability)
Was [£399.95] Inc. VAT
Only £377.99 inc VAT.
ORDER NOW
Gigabyte ATi Radeon HD 7950 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card @ £323.99 inc VAT
Features:-
- Core Clock: 900MHz
- Memory: 3072MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 1792
- Bus Type: PCI-Express 3.0
- Display Connectors: 1x Dual Link DVI, 1x HDMI & 2x Mini-DisplayPort
- HDCP Capable
- OpenGL 3.2 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 3 Years
Was [£339.95] Inc. VAT
Only £323.99 inc VAT.
ORDER NOW
Gigabyte ATI Radeon HD 7870 OC Windforce 3X 2048MB GDDR5 PCI-Express Graphics Card @ £269.99 inc VAT
Features:-
- Core Clock: 1100MHz
- Memory: 2048MB GDDR5
- Memory Clock: 4800MHz (Effective)
- Processing Cores: 1280
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- Shader Model 5.0 Support
- ATI Avivo HD
- Warranty: 3 Years
Was [£279.99] Inc. VAT
Only £269.99 inc VAT.
ORDER NOW
Gigabyte ATI Radeon HD 7850 OC Windforce 2X 2048MB GDDR5 PCI-Express Graphics Card @ £199.98 inc VAT
Using high quality components on graphics cards is the key factor for having a long lasting, stable and reliable product. GIGABYTE is again setting a new standard by using Ferrite Core Chokes, Low RDS (on) MOSFET and Lower ESR Solid Capacitors, providing the stability and reliability from their high-end graphics solution. In addition, GIGABYTE Ultra Durable 2 Edition graphics cards now feature a sophisticated layout topology. This state-of-the-art power design from GIGABYTE delivers the ideal integration of thermal, electric characteristics, digital signals, power circuitry and optimum placement of components for enhanced graphics performance.
The special inclined dual fan design effectively minimizes the flow of turbulence between two fans and enhances heat dissipation of hot area right underneath each fan. By unique design, WINDFORCETM 2X even enlarges air channel on the graphics card vents and creates a more effective air flow system in chassis. This special design helps heat dissipate quickly from GPU. In addition, WINDFORCETM 2X is equipped with 2 copper heat-pipes which strengthen the speed of heat dissipation.
Supporting multiple independent display outputs simultaneously, AMD Eyefinity technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience.
Features:-
- Core Clock: 975MHz
- Processing Cores: 1024
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Was [£214.99] Inc. VAT
Only £199.98 inc VAT.
ORDER NOW
Gigabyte HD 7770 OC 1024MB GDDR5 PCI-Express Graphics Card @ £109.99 inc VAT
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections.
As opposed to the stereotype, GIGABYTE is able to maximize fan size to 10cm with the latest cooling design. With a 10cm fan, the card is virtually silent that its noise level runs much lower
Features:-
- Processing Cores: 640
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Only £109.99 inc VAT.
ORDER NOW
Gigabyte HD 7750 OC 1024MB GDDR5 PCI-Express Graphics Card @ £89.99 inc VAT
As opposed to the stereotype, GIGABYTE is able to maximize fan size to 10cm with the latest cooling design. With a 10cm fan, the card is virtually silent that its noise level runs much lower.
- Core Clock: 880MHz
- Memory Clock: 4500MHz (Effective)
- Processing Cores: 512
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Only £89.99 inc VAT.
ORDER NOW
The WindForce 3X cooler in particular is very impressive and these are some great deals. :)
Windforce GPUs are amongst the most quiet cards I've ever owned, even under huge loads. I'm going back to Gigabyte Windforce when I do my next graphics card upgrade for sure. My current card is like a airplane taking off in comparrision...
Totally agree with this. I had my GTX 4601GB clocked pretty damn high and that thing was really quiet. The 560Ti DCII I have now is inefficient and noisier at 50% than the gigabyte was at 100% (honestly). Totally recommend the Windforce coolers :-)
This. Impressive cooler on my 460 as well. Will be taking a long hard look at the Windforce 670. Would be even better with a black PCB as is oft said. Makes me wonder why Gigabyte don't listen to their customers and change it.
