Damn Parcel tape stuck to my Super Lanboy
Well if you're not worried about scratches and are thinking of spraying, you could just sand it down/off.. etc. If no other method works.
ChoÞÞer said:
WD-40 - hair dryer and somethink to wipe it off with..
yep, that works, btu i never use a hair dryer :S
the best stuff is'pannel wipe' its the stuff i use to clean surface wax and grease off before i paint things. and it bruings sticky residues off in an instant :D
MeatLoaf said:
Any way i can get this tape off the top of my tower? Ive already scratched it by trying boiling water and a scourer?
If i can get it off then i can always repsray the top so im not to bothered about the scratches?
But how do i get the tape off??
http://img473.imageshack.us/my.php?image=1005776ra6.jpg
Why the hell did you use a scourer? :confused: Hot water doesn't remove tape glue. Should have used WD40 or meths with a soft cloth.
If in doubt - use white spirit. Good for removing sticky substances and for starting troublesome bbq;s
Akasa TIM clean, a citrus based solution, must be the best product I have ever encountered for removing gunk of any kind. That includes sticker residue, marker pen, and their variants, as well as thermal interface material - and it never leaves any sort of stain or mark! It even tastes good with vodka! (only joking don't try this at home)
