Damn spyware help!
27 Jul 2005
Hi I was surfing the web the other day and my computer started going mad and automatically installed a program called spy falcon,
Now i have tried removing it but it just re-installs its self after half hour or so, and i get this annoying pop up in my tool bar saying my pc is infected etc its not a windows message it just looks like one, and the ocon is a red circle and the windows update symbol it flicks between the two.
I have tried
AVG, ad aware and spy bot but cant detect it, i have even deleted the file but it re-appears, can anyone suggest something i can do to remove it?
thanks
I have tried
thanks
I really feel for you mate.
We had a machine that had this installed last week and it took me over a day to clean it all up.
No matter what I threw at it I couldn't get rid of the damn thing.
It really does embed itself in there.
Link below:
http://www.spyware-removal-guideline.com/spyfalcon-removal
Follow the "Manual Removal Process" as detailed towards the bottom of the above link.
Download the files you are told to, run them in the correct order - basically do as this article tells you.
It was the only method I found that worked.
Marshmule said:
Got round to doing it, that guide is excellent, took me 10 minutes! thanks again
Pleased I could help - after ripping my hair out over this one for a day if I can save anyone's sanity it's worth it!
