Evening Gents,
Hopefully some of you have some experience with controlling/dealing with damp issues.
The property in question is a mid-terraced cottage roughly 100 years old, renovated 3-4 years ago by the previous owner, including a new roof.
Basically the damp is bad in one of the walls/ends in the loft and is now showing in the master bedroom beneath.
One side is stone (possibly original?) and one side is partitioned with insulation/plasterboard etc (neighbours that side went up into the loft).
The stone side is the problem side.
Here is the stone side:
I have been reading the damp values of this wall and generally the red area is reading 27-33% (high), yellow 20-26% (medium to high).
^ That reading was taken just above the beam low down on the wall, the master bedroom side.
And just to give a full picture of the loft, here is the opposite end, the boarded side:
Generally the damp readings on this are far lower (10-19%) except the main wooden strut in the centre, which is also reading high at around 25-30%. This side generally doesn't concern me as we have no real issues below on this side of the house.
Going back to the stone wall...
Now I noticed the previous owner has shoved insulation down the side gap between the last beam and the wall itself. I have started removing half of it (highlighted in red) to have a closer look.
I was thinking maybe too much insulation is being used as air still needs to be ventilated in the loft?
And finally here is the damp patch showing in the master bedroom below:
Generally wall reads at 10-12% until it shoots up to a 24-26% on the damp area.
My question is what is the most likely cause of this?
Too much insulation used? Leaking roof?
I can find no actual water presence/wetness anywhere. No other areas are affected. Lower rooms/ground floor is fine.
Anyone had similar before?
Any advice appreciated.
edit: added to description, house is a mid-terrace, so this wall is not external.
