Dan A3 psu recommendation
24 May 2011
Hi
I am currently have a dan a3 with 360aio (bequiet lightloop) along the top and a lian li edge 1300w powering a 9800x3d and a 5090fe.
Thinking the. Edge would fit better in my cousins pc so just considering a replacement for the psu in my build. Any recommendations? Want to play it safe with over 1kw would ideally like it to be white but can see the options are limited. Does anyone have any experience/ advice?
I have seen a fair few people mention the sf1000 causing coil whine issues? I appreciate it's probably pay your money and take your chances but have you had issues?
The ones I have looked at at:
Asus strix 1000-1200w
Asus loki sfx l
Corsair sf1000
Corsair rm1000e shift (seen a guy bend the cables but the 12v makes me nervous about this so doubt i would risk it)
No issues at all, it's a fantastic PSU. Very quiet too. My only gripe was how short the cables were - I have a thick bunch of cables running across the centre of the case rather than being nicely tucked away. It looks fine due to how I tied them up, but still, not perfect.
I'd imagine any PSU with a decent warranty would be fine as long as it fits nicely and meets the minimum supply you need.
