Dan Case
Hey,
So finally managed to grab myself a DAN case, was wondering on the water coolers listed below, do I still need to buy a bracket for the radiator to work in the DAN case?
https://www.overclockers.co.uk/ocuk...cooling-bundle-with-noctua-fan-bu-0d4-tl.html
Also, I ordered tonight, what's the current situation with dispatch will I expect it this weekend or likely next weekend?
you don't need a bracket, I had one, is a challenge to fit under the power supply without snagging the fan and the tubes are tight to route too.
Be careful what CPU you pair with it, I found it very limited when cooling.... ran hot, heat soaked quick and was not very effective. I went back to a Noctua Li9 air cooler which was just as effective, easier to maintain and quieter...
