** DAN CASES A4-SFX V3 MINI-ITX CASE NOW AVAILABLE **
OcUK Staff
26 Nov 2014
Stoke
Now available to buy, we have the Dan Case A4-SFX V3. The V3 of the immensely popular Dan Case A4-SFX has added a Lian-Li Riser Cable, which conforms to PCIe 16x Gen3, and is the same as you'll find in all Lian-Li chassis. This means lead time and availability can be improved, along with a reduction in unit cost. Further to this, there has been adjustments to the USB3.0 internal cable to make it compatible with the Asetek 92mm AIO, improvements to the power button to optimise the pressure point, addition of mounting points for the HDPLEX 400W HiFi DC-ATX PSU, and an added mounting bracket for a 120mm AIO. Of course it's available in both Black and Silver as usual, and with limited stock quantity I'd suggest getting your orders in to avoid disappointment.
Dan Cases A4-SFX V3 Mini-ITX Gaming Case - Black @ £209.99 inc VAT
Ultra small form factor case, sleek and minimalist design, space inside for full-size graphics card, optimised for water or fan cooling
Only £209.99 inc VAT.
ORDER NOW
Dan Cases A4-SFX V3 Mini-ITX Gaming Case - Silver @ £209.99 inc VAT
ORDER NOW
These cases will fly!!!
