- 7 Feb 2004
Just a noob question but I used to hear lots that its dangerous to give out your ip address.
Why is this?
Why is this?
Why is this?
Jeremy Clarkson gave it out. It ended in tears.
Were they not his bank details?
if someone gets your ip though its worrying how they can get your rough location etc
if you're on the other side of a router is is true that only the ip of the router can be seen?
Rough location? As in the right country?
Depends on the ISP and how diligent they are...anything larger than a /29 registered should have the user address on the RIPE database really.
If you're running NAT they'll only see the outside of your router, which I expect covers most people here (and those, like me, running public IPs internally will likely have enough experience to have a decent firewall)
no as in area and what isp server you're going from. I've put a post on here about a problem i've got where someones gained access to my wifi internet and caused some problems and an email I had came back with my routers ip address and the location of the nearest isp location/centre thing
whats a decent firewall that could be used and what are the benefits of it?
