Dansguardian and squid
22 Jan 2005
Surrey
Hi all,
I currently run a gateway machine at work running RHES3, it runs the following services:
Transparent proxy using squid and IP Tables
DHCP
DNS
Web Services
I can't be bothered to read the dang manual at the moment, are there any quick tips to integrate it with my existing transparent proxy setup, or do i need to man it ? !
Thanks for your help people.
what's your current proxy setup? the point of the transparent proxy setup using squid and iptables is that it requires no setup of the clients at all, it just appears as a 'magic caching router'
That's exactly the reason it is setup, as I don't have to manage workstations, and clients cannot just turn it off if they don't want to use the proxy for some unkown reason.
I don't know if you understood, but I currently have transparent squid proxy setup on the box, i just want to integrate dansguardian.
