Hi all,
Can someone help me please with using command line switches with netopv9 please.
Please see below fo the switches link:
http://help.netop.com/support/documentation/command_line_switches.htm
So, following in the instructions I try running the following path:
c:\Program Files\Danware Data\NetOp Remote Control\GUEST\NGstw32.exe /H:192.141.131.10
And it doesnt work. ( the server I want to connect to is on that IP.)
If i run:
c:\Program Files\Danware Data\NetOp Remote Control\GUEST\NGstw32.exe it does load the application.
where am i going wrong please?
Thanks,
If i run:
Thanks,
