thanks! is this the limit the frequency can go to or can it be overclocked ? also is it possible to overclock the ram timings >yes 1600mhz x2 = 3200mhz
frequency can be overclocked, by how much it depends on your setup. Ram timings (latency) should be lowered, again by how much it depends on your setup and mainly the ram itself.thanks! is this the limit the frequency can go to or can it be overclocked ? also is it possible to overclock the ram timings >
tied overclocked my frequency just a little but it reboots to bios , so I guess my ram wont overclock which is strange as I thought it could be .frequency can be overclocked, by how much it depends on your setup. Ram timings (latency) should be lowered, again by how much it depends on your setup and mainly the ram itself.
what is your CPU and motherboard? the 8Pack RAMs are b-die and certainly they can comfortably hit 4000Mhz cas 17-19 on Intel platform.tied overclocked my frequency just a little but it reboots to bios , so I guess my ram wont overclock which is strange as I thought it could be .
also this is what my cpu z looks on auto setting , never overclocked ram before my cpu is overclocked 3.8ghzwhat is your CPU and motherboard? the 8Pack RAMs are b-die and certainly they can comfortably hit 4000Mhz cas 17-19 on Intel platform.
Hi ! what soc voltage and ram voltage do you recommend ? "gb ab350 gaming 3, ryzen 5 1600On amd its hit and miss if you can go higher than 3200mhz. With the high end boards you have a better chance. Try 3333mhz default timings tune soc voltage...
