- 17 Nov 2011
- Telford, Shropshire
Hi people...
I'm planning on a new ITX build over the coming months (see bellow) and was wondering if the 'BeQuiet Dark Rock LF' CPU cooler will physically fit onto a 'Gigabyte-GA-Z170n Gaming 5' motherboard? as i have come across a few stories over the tinterwebs that this particular cooler may not fit because of the heat-pipes will be touching the first occupied memory slot and bending the memory module.
As anyone else used this cooler on an ITX motherboard? specifically the GA-Z170n Gaming 5
Cheers in advance.
Leon
(W.I.P)
MOBO- GA-Z170N-Gaming 5 Mini ITX
CPU- Core i7-6700K LGA1151
COOLER- BeQuiet Dark Rock LF
MEM- Corsair Vengeance LPX 32GB (2x16GB) DDR4 3200MHz Dual Channel Kit - Black
CASE- Silverstone Sugo SG08 Case with 600w PSU - Black
Maybe..............................................................................
GPU- Gigabyte GeForce GTX 1080 G1 Gaming RGB
Cheers in advance.
Leon
(W.I.P)
