Dark Rock Pro 4 - middle fan recommendations
15 Apr 2009
HI All - wondered if there were any tried/tested recommendations for replacement middle fan? Mine died dramatically the other day. Temps are fine at the moment, even when gaming, but worried when / if a heatwave arrives!
The Silent Wings BQ SIW3-13525-LF-PWM fan doesn't seem to be available and looks like I would need to be careful on size/depth of any replacement...
Almost wonder if I should just get a Peerless Assassin or something similar from Thermaltake instead! Wouldn't actually cost that much more.
Looking to hand over this system to the kids soon and build myself something new from scratch anyway...
Can you can get it replaced under warranty?
5yrs old and only 3yr warranty unfortunately.
May as well go with the Peerless Assassin, they're dirt cheap
I think I'll do that for about £30 or the Phantom Spirit 120 Evo if I see it come lower than current price of around £50.
Currently the cooler is performing well with just the one fan in my FT02 case (good airflow from the 3 x 180 intake fans at bottom that push through the CPU cooler and out the top). Keeping an eye on it though and summer temps haven't yet peaked!
